I have a 98 Johnson 200HP on a 23 ft. Wellcraft center console, that locked up on Dec. 9,2003. The motor was warmed up for about 20 minutes and everything was fine. We cruised for about 12 miles at 5000 rpm. The motor started missing for about 5 to 10 seconds and cut off. The VHF, GPS, GPS charplotter, and fishfinder, all cut off at the same time. Motor would not turn over. Volt gauge showed 2 volts. The batteries were ok and the volt gauge showed 14 volts when we left the dock. I was only using 1 battery at a time. Had to be towed in. Anyway the motor is at an authorized Johnson sales and service dealer and is completely apart. The # 3 piston is melted and about 1/4 of it broke apart. The cylinder wall is scoured and the rod is damaged at the crank end. The crankshaft is also damaged. Motor would not turn. Carbs were checked and were fine. Stator is burned up. VRO pump check valve was letting oil back into the fuel line. The mechanic could not say exactly what went wrong first and could not say what the cause was. I have a 5 year extended warranty that I bought with the motor new in 1999. The warranty people sent a marine surveyor to look at the motor and took pictures. The warranty people declined to pay and determined the problem was detonation. Any loss caused by improper timing, detonation, preignition, poor quality / or contaminated fuel is not covered by the agreement. The motor is tuned up twice a year and the fuel is fine. The motor had about 400 hours on it and was not abused. My question is, if the stator burned up, could it have messed up the timing and burned the piston? I'm thinking about contacting a lawyer. Any help on this would be greatly appreciated. Thank you, Jim
