I have a 20 ft sweetwater toon and have a galvanized trailer with a single axle that pretty much grenaded this weekend. Believe it is a 2000lb axle. it is a bunk style trailer with a appox. 5ft axle that tucks the short wide pontoon tires between the frame and toons. The boat rocks back and forth real bad and figured this might have somthing to do with my axle having the bearings go early. Would a 75" axle help with the sway better? The only thing is I will have to "lift " the suspension to make the tires clear the pontoons but would ride better. Should I have another identical axle put in but a 3500lbs one, or up to a 3500lbs wider axle???? the shorter one would swap back easier and the longer one would require some fab work but thats ok. I am just thinking about long term reliability. Thanks for any suggestions.
