I float a 1986 22CC Hydra Sport onto a tandom/dual axle Magic Tilt trailer.
My boat, fully decked out + fuel I estimate weighs in at about 4000lbs.
Presently when boat sits on bunks you can see some slight deflection outward in center of bunks but I don't think enough to be concerned about.
I am considering replacing the bunks on my trailer soon. They are 3" x 10" x 10' Cypress Wood, that are mounted on their edge, but sourcing Cypress in my area practically impossible.....
My Plan 'A' is possibly using Pressure Treated Pine cut to same size,,,,, anybody know of any possible problems with that plan?? There seems to be some concern about galvanic corrosion reaction due to chemicals in the PT wood???
My Plan 'B' would be to use some local sawn Aspen wood, same size,,,,, which is more easy to get here??
I am wondering about these wood types and what would be the strongest/toughest for this purpose with least deflection against weight loading??
Any suggestions or options available instead of wood bunk materials,,,,, like aluminum I-Beams maybe???
Anybody have any advice or experience in this area??
