Re: Bulb in fuel line not staying hard.
The fuel line hose bulb is not supposed to stay hard. ...
...while the motor's running. Just wanted to clarify. It won't be firm during operation cause the pump is pulling fuel through it -- but should be firm when the motor shuts off and stay hard all day. Seek immediate medical attention after 4 hours.
Listen close at the quick disconnect fittings (both ends) for the wheezing sound of sucking air while you pump the primer bulb. Or, those fittings will wear out over time, so if you haven't done so in the last few years, go ahead & replace 'em now. They aren't that expensive. If it doesn't solve the problem, keep the old ones as on-board spares.
In my experience, if the fuel pump diaphram gets perforated on that motor, gas will dribble out that hole on the back of the housing when you squeeze the bulb and also while the motor's running.
Try this: pressurize the line in the morning then check it after 5 or 7 hours. If it's still firm you know the fuel line is holding; suspect a weak fuel pump. If pressure doesn't hold for more than a couple hours (motor not running), it's a problem in the line. Any other result I think would be "inconclusive."
btw, the manual says that pump is not serviceable, but sierra repair kit #18-7820 fits it just fine.
