Mark42
- Oct 8, 2003
- 9,334
Anyone know of a supplier or manufacturer of fiberglass mat that is compatible with epoxy resin? So far everything I found is not epoxy compatible.
If there are no epoxy compatible mats available, what do you think is a good substitute to build up thickness and strength quickly? 10oz weave? or heaver?
BTW, if you are unfamiliar with why mat is not compatible with epoxy resin, the reason is that mat fibers are held together with a glue that disolves in polyester or vinylester resin. This glue holds the mat together, and allows the glass fibers to be in direct contact with the resin when resin is applied. If the mat is used with epoxy, the glue does not disolve and the glass fibers do not come in contact with the epoxy resin.
