steepcreeker
Thread starter- Joined
- Dec 20, 2010
- 4
Hey all. Long time reader first time poster.
Got a project I've been thinking about doing for a while now but could use some fresh ideas.
To get to our boathouse I have to go down a long set of steps to a gentle slope to a flat spot at the water. Going down/ up isn't too bad unless you have to carry a large cooler or other heavy stuff. What I've thought about doing was building a "sled" on a set of rails much like rail lift for pulling boats out of the water just not as heavy duty. The total drop is about 25-30 feet in about 125' of travel. Most of the drop is towards the top but not more than 45 degrees steep. What I have envisioned is taking 3-4" sch 40 PVC and making a set of rails about 2-3' apart all the way to the bottom. The sled would be a "box" of some sort with 4 wheels which would probably be something like golf cart or 4 wheeler rims (something small). The sled would be pulled with cable on an electric motor/ winch. Since I'm not using this to carry people I'm not too concerned with cargo weight since it will be less than 100lbs.
Just wondering if anyone has done or seen something like this.
M
M
