erikgreen
- Jan 8, 2007
- 3,105
Hi all -
I just finished my new transom, and I'm moving on to building new motor mounts for my 302 ford block. The originals were integral with the old fiberglass deck, and would be impossible to replace (the stringers are coming out the rest of the way soon anyway).
Here's the issue: I need to make the mounts 38" by 7", and 5 1/4" tall on the inboard sides, sloping to 4" tall on the outboard sides. So, the bottom of the mount needs to get an inch and change shorter in the 7 inches of width to match the hull curve (deep V hull).
The only ideas I've had so far are to laminate ply on edge, using slightly narrower pieces progressively toward the outboard side, and keeping the top edge even. This gets the slope, but I'd be putting a vertical lag bolt into plywood edge-on.
Second idea: Laminate ply strips to the right size, then use a metal cutting bandsaw and a jig to cut the bottom of the stack to the right angle for the slope.
Tashasdaddy suggested maybe using some angle iron with the vertical ply idea to send bolts in from the side instead, but I doubt my ability to make that strong enough.
Other ideas gratefully accepted. I own only a trim router, I don't have a table saw. I do have a small set of machine shop tools, power hand tools, a drill press, and some air tools.
What's a good way to make a motor mount for this motor? It's 188 HP, and mounts using four large lag bolts through the adjustable motor mounts, plus the transom plate bolts.
Erik
PS: Here's a pic of the mounting location, I still have to remove half the old mounts:
Erik
