Tightlines72
- Aug 15, 2015
- 18
Hello iBoats,
I have been on the forums here for a while now; mostly reading but occasionally asking questions with great results. I have an old flats boat that had a completely rotted deck though luckily after removal, i found that the stringers were solid. Everything is now out of the boat and everything has been ground, and per the wise advice on here I have my order from US Composites on my way to my house. I thought I had a good plan, but after a few eager nights of no sleep, I am starting to second guess myself.
My question comes in how best I should attach the raised aft and bow casting decks. The original design had two bulkheads rising from the bottom deck that ran perpendicular to the hull and ended about 1/2" below the top of the gunnels to allow the deck to sit flush with the gunnel. Each of these bulkheads was 1/2" marine ply that appeared to be simply tabbed to the hull. My original plan was to attach my new ply wood bulkheads to the deck with SS deck screws from under the deck before installing, then PBing, glassing, and tabbing the deck in, then finally tabbing the bulkheads to the hull and to the deck.
My concern is that the bulkheads won't sit completely vertical and will provide an uneven support structure for the deck to sit on. Beyond that, I'm worried that the weight of the top deck and people standing on it will cause the bulkheads to buckle to one side or another.
I know this probably is hard to follow, so if someone could post a suggestion as to how to install bulkheads onto a bottom deck to allow for the construction of a raised aft and bow deck, I would be hugely grateful. I'm not great with paint, so please forgive these pictures.
Old bulkhead layout:
New bulkhead plan:
New bulkhead plan:
