EricJRW
Thread starter- Joined
- Feb 3, 2010
- 488
Re: Building a shroud - Any advice?
Well I'm realizing there is more than a "closed" component. Since there is nothing across the back, the two sides can flex quite a bit, especially at the top corners... So I need something not only to hold it down, but also in place. I like that latch idea though, so maybe I just need a small pin (or screw) to protrude slightly above the back corners to hold everything in place horizontally.
