tightstripes
Thread starter- Joined
- Jul 21, 2009
- 22
I'm looking to try to build or buy a portable salwater livewell for my small 17' boat. I'm trying not to spend a ton on the project but any input would be appreciated.
I have an old bilge pump that i was thinking about trying to use... My initial thoughts were to submerge the bilge pump in the saltwater to feed the tank, then just put a drain on the top/side of the tank to drain older water. Attach a switch to the wire connecting to the battery, so the pump wouldn't be pumping at all times.
I'll mostly be using it to store live mackerel/pollack for 3-6 hours at a time while I'm out fishing.
I don't have a lot of deck space on the boat.
Questions:
Is this a stupid idea?
Will the bilge pump motor burn out quickly since it probably isn't built for this type of application?
Will the bilge pump drain the deep cycle battery too quickly?
Do any of you have any other suggestions?
Also, any thoughts on something like this?? http://www.cabelas.com/cabelas/en/t...cabelas/en/common/search/search-box.jsp.form1
Questions:
