Re: Building a center console
Yup. That's the girl. It been so on and off I haven't been very attentive. Work seems to be slowing a bit, and the weather looks like it might allow me to do some work (it's outside under cover so rain is a problem). I am going to consolidate into
here
Here are some current pics...
I rebuilt the center of the decking where I had this:
In retrospect, I should have removed the entire cap before starting...let that be a lesson to those starting a project.
After finishing the center deck, I dug a little more into the back area of the boat where you see the seating in the above picture. Well it was paper thin and I was really bothered I had not check this before. Stupid new guy trick. So...stupid me...still didn't want to pop the whole top. I strategically chose a place to cut and removed the rear cap.
Here is it laid against the house. Note the red circles...rotted wood under the seating area and venting. Other than that it's solid as a rock.
Once pulled the cap off I could see the real damage. OMG...what a mess. There were two boxes (created for flotation) and full of water logged foam. The foam below deck was soaked and the stringers were... anyhow, the transom was shot and I knew that. Here the picture after I removed most of the wood:
After numerous attempts with a chainsaw, homemade scrapers, long pry bars, and anything else I thought would work and since I have removed the back cap, I decided to remove the inner skin.
After cleaning out the stringers and the remaining transom wood pieces, I was stuck with this bilge area and had to make a decision since I couldn't remove the remaining wood between the bilge and the transom outer skin.
I chose to remove the entire bilge and rebuild the stringers and bilge along with the transom. That's where I am now which brought to the center console question in the other post. I figured since I was going to reconfigure the area mentioned, I would make this little girl into a center console.
I will post as I progress.
Thanks.
