buggered up tnt manual release screw
brokeboater
the manual release tnt screw on my 99 200 johnson was messed up when i bought this engine. i really would like to remove it and either fix it or replace it. the groove/slot that you use to turn it out with is so messed up it will not let me turn the thing. there is a snap ring around the outside of it. is this all that holds it in? if not, what is involved in removing it? i have an omc factory manual but it doesn't cover tnt. thanks!!!
WillyBWright
Re: buggered up tnt manual release screw
The snap ring prevents the screw from coming all the way out. You should be able to screw the valve out with the snap ring removed. The new one will just screw back in, then reinstall the snap ring.
brokeboater
thanks. i can't tell if it can be done without removing the whole unit or if it can be done thru the hole. i'm also going to have to figure out why it won't turn :confused: , then how to turn it. i assume it turns out counter clock wise?
