Hello,
I read a lot of threads about adjusting motor. I have a 1990 90 hp Force. I read sometimes BTDC timing settings should be made while motor is running at high rpm or with WOT, sometimes cranking motor with starter and sometimes cranking motor with starter without spark plugs. When I say setting while motor is running, I mean just checking the marks not adjusting. I always check the timing while motor is running at WOT. I adjust the timing while engine is stopped.
Berndie
Berndie
