bruceb58
- Mar 5, 2006
- 30,810
Re: phase charging 3 batteries
You need to add and isolator or a combiner to his circuit otherwise the trolling motors would pull down your start battery. Problem with the isolator is that you won't be able to fully charge the batteries. I have a feeling, your alternator does not have a remote sense line.
If your trolling motor had a different type of configuration where you supplied it strictly 24V, this would work:
http://www.yandina.com/trollinfo.htm
I remember that Stealth charger that you mentioned before. You need to find out if the grounds are not common with eachother which you need for your application.
