gbak
Thread starter- Joined
- Jul 31, 2011
- 23
My cooling sensor (the sensor mounted in the cylinderhead) is broken!
As it gave intermitent ohm valures when measuring, I opend up the molded sensor body and below is what I found inside.
Looks like some kind of mini glas PTC resistor inside the molded plastic tube.
I tried to solder without any luck, it is to small.
Shouldn't be to hard to change that resistor part.
Can anyone confirm that it is a PTC resistor?
What value should a replacement resistor have?
The arrow points to what I believe is the PTC resistor (or what is left of it)
