Short version: Remove the lower mount clamshells. Remove the hex nuts from the three upper rubber mounts (just loosen the front one several turns). Remove the vertical throttle shaft and fuel hose. Now swing the lower end rearward and lift the whole motor out of the swivel bracket. Sure does help if you have a hoist of some kind. Swivel bracket can now be replaced.
Thank you ,now I can begin .I can use my hoist come along to separate ,thanks again ,I am very much a rookie at this ,but their is always the first time .
