Broken marker light
cd619
I have a broken marker light. The light itself works, but the plastic base is cracked to the ground won't stay connected. However, it seems that the base is riveted to the frame.
I'm not even sure where to get a direct replacement and if I could just drill out the rivets and screw in a new one?? Any insights?
https://ibb.co/F8YyDyX
JimS123
Designs change often, so forget about a direct replacement unless the trailer is only a few years old.
IBoats carries a dozen or so different types. Buy 2 and replace both of them so it looks nice.
tpenfield
What Jim said . . . Scrap the old light base and go with a new one of similar shape/style.
Mben
Just get some measurements of the current lights, search on amazon for same size. You will have to drill out the rivets but you can easily use a self tapping screw to secure the new ones. LED markers are pretty cheap on Amazon
