Re: broken brass fitting in elbow
Big EZ out will work. Also, try tapping the end of a flat ******* file into it with a hammer. You can then grip the file with an adjustable wrench and back it out that way.<br /><br />Oh yeah, heat is your friend. Use a torch to heat manifold and it'll help as well. That said, getting brass out of iron is about the easiest of these sorts of tasks.
