dlogvine
Master Chief Petty Officer
Thread starter- Joined
- May 4, 2015
- 839
I'm replacing the bellows housing and transom plate for Alpha One Gen 2 outdrive. When I removed the v-pipe I saw that two bolts on the bottom were broken. When removing the trim sender, another bolt broke. Two of the V-pipe fastener bolts im planning on removing by welding a couple nuts on the top and using the impact driver to break the fusion. For the trim sender retainer bolt, i tried to remove it by drilling it out, but first the bolt extractor broke and then the drills started breaking like crazy. I managed to frill out about 1/2" hole that will fit the bolt, but the remainders of the bolt extractor or the bit were stripping the tap. I managed to get a thread strong enough to hold the bolt, but I wonder if there is a better way to fix it?
For the V-pipe bolts I think welding the nuts will heat up the bolts enough to break them lose, but I saw people using the 12V battery to heat up the bolts via current and break the fusion. Is it a feasible way?
