In removing the water cover 2 of the bolts snapped. I have tried using an "easy-out" with no success. The easy out broke off. The bolts are not coming out.<br /><br />The way I see it I have 2 options:<br />1)drill out the old bolt and re-tap the hole leaving me with 2 holes / bolts of a larger size than the rest; and <br />2) drill out the old bolt and insert a helicoil -(threaded bolt jacket)into the hole allowing me to use all bolts of the same size which means less to remember next time it has to be taken apart.<br /><br />My question is canI use a helicoil in a marine environment? If so what material should it be made of? Who makes it?<br />thanks
