erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
I was cleaning up my Chevy 350 block getting ready to put it back together with Marine gaskets and bolt-ons, when I discovered that one of the head bolts was broken off.
Apparently it was broken off by the previous owner and left in... the engine ran without the bolt in.
Being the anal type I am, I decided I wanted to get the bolt end out and put a new bolt in its place. So I went and bought a titanium nitride drill, and a bolt puller sized for 1/4" drill bits.
I drilled the center of the bolt out, then following the directions on the puller I tapped it into place, hitting it lightly 3 times. The third tap the bolt puller snapped off!
After expressing my disappointment at this development with a few choice words, I tried drilling out alongside the bolt to either side... I figured I'd damage the hole a bit, but I could weld it or even JB weld to fix it, and at least I'd have the bolt out.
No luck. So now I have a block with one bolt I can't use, and I can't see a way to get the broken bits (which includes part of a super-hard bolt puller) out.
Do I need to get a new block? I just sold my extra 350 block
Any chance I could run for a season without using that bolt hole? Like I said, the block ran before.
Suggestions deeply appreciated. Here are a couple pics of the problem.
Erik
Erik
