rickfisher805
Thread starter- Joined
- May 12, 2014
- 24
i have an 86 15hp evinrude and when trying to inspect the water and exhaust rubber grommet for the upper water tube i twisted on bolt off the one that is next to the exhaust tube. it was corroded and i should have know better than to use force. my question is do i really need to remove or can i get by without much ill effect by just having the other three bolts down tight. i tried some liquid wrench soaked on it for a couple of days and i couldn't get it to budge there's only like a quarter inch of mashed bolt left. if you guys have any ideas about the best way to remove or do i just try to drill it out as center as possible and try to knock the threads loose? any suggestions would be appreciated.
*** i guess they are both called water tubes it broke off next to the short one
