Broke flywheel pully bolt
asubrew
After letting the Marvel's Mystery Oil sit in my engine for a couple weeks, i tried rocking the flywheel pully bolt back and forth...IT BROKE OFF. I thought I was getting movement, but it was only the bolt bending back and forth. What do I do next? I heard that if I connect two bolts to the flywheel pully, I can use that as leverage. Thoughts? Thank you in advance.
'85 OMC Stringer with 4.3L V6
Here's my original post: http://forums.iboats.com/showthread.php?t=288498
Don S
Re: Broke flywheel pully bolt
Pull the heads off. You will probably find the engine isn't worth saving. Let alone worring about a broken bolt at this point
asubrew
Will do. I am awaiting my shop manual. Thank you!
Ayuh,.... Just alittle FYI,.... The Flywheel is on the Other End of the motor.....
