Re: Briggs & Stratton 16.5 HP Tractor: It's Possessed. Arrrggghhhhhh!
I can't believe this.<br /><br />The new coil? It went bad. Or maybe it went bad... I don't know anymore!<br /><br />The tractor ran fine after I replaced the coil. Then just a couple days later, I was out doing some serious grasscutting, and the d***** thing died, just outa the clear blue. Being a bright sunny day, it's hard to be sure, but it looked as though I was getting no spark again. Hmmm.<br /><br />So, I put the old coil back on, and it fired right up. I put silicone all over it to keep the arcing to a minimum. Then I boxed the new [failed] coil back to the good folks I bought it from, and they sent a new back to me.<br /><br />I installed the second new coil this morning, and the tractor fired right up. So off I go, a-cuttin' grass again. After about two hours (big yard), the thing dies on me AGAIN.<br /><br />I learned in the electronics game that you don't keep replacing the same component over and over again. You look under the bed once, maybe twice for a pair of shoes, but if they ain't there, they AIN'T THERE.<br /><br />This ignition system is so rock-simple, I don't see how it can fail unless the magneto/coil takes the proverbial dump. I can see the fuel being sprayed down the carb. I know it's getting fuel.<br /><br />Okay. I am getting spark. I am getting fuel. If it doesn't run, then it's got to be a cam timing thing, right? But how in tarnation does the cam timing go bad, then fix itself, then go bad, then fix itself, repeatedly?<br /><br />So now I am snooping in the exploded view of the motor. Lo and behold, horrors upon horrors, I see that the camshaft is gear driven, and that there is a key that indexes the crankshaft to the camshaft drive gear. In my overstressed imagination, the key is damaged, the camshaft drive gear is slipping periodically and throwing the timing all outa whack, and then when the gear has slipped 360 degrees, then it catches again---for a while--and the tractor runs for a bit.<br /><br />There are demons in my tractor.<br /><br />Well, maybe not. Maybe I am overlooking the stupidest, simplest thing. Can anyone out there corroborate my hypothesis, or refute it?<br /><br />Pleeeease! My sanity us at stake. I may just go buy a new John Deere tomorrow and try to give the ol' piece o' junk away!<br /><br /><br />-dd-
