Briggs and Stratton 5hp outboard
cmarkshsv
How much freedom should the clutch move on the spring loaded output shaft? I just purchased a used outboard that has propeller broken and it appeared to be stuck in Forward. I removed the propeller and shaft and noticed the it takes a lot of force to move clutch along shaft. How much movement should this have?
