Breathing life into a Johnson 4 Seahorse
k1loran
Just acquired a Johnson 4 Seahorse which has been sat unused in various sheds for years, but was serviceable when last used. Mod 4BRL 76M, Serial B 8404. <br /><br />Any one there could help with age/history?<br /><br />Manuals?<br /><br />Engine won't turn - where's the best place to start!<br /><br />Thanks for any advice,<br /><br />Alistair
rwise
Re: Breathing life into a Johnson 4 Seahorse
Downlands<br />Welocome to the board!<br />4RL76 = 1976, I don't see one listed "4BRL"<br /> This site's manuals <br />Pull the plug/s and spray wd40 or other good pentrating oil in the cylindar/s. let it soak and repeat. then using no tools just your hands try to rotate the flywheel. rock it back and forth adding more oil as it comes free. it may take several days to free it up, and you may need to pull the heads and inspect the cylindar walls. there are many posts on this. and lots of good info here for free reading! there are many old engines saved with info here.<br />Richard
k1loran
Richard,<br /><br />Many thanks, I was grateful for your reply. As you saw I have only just discovered the forum and the wealth of info contained in it.<br /><br />Perhaps the 'B' was for the UK market where the engine was bought.<br /><br />WD40 worked just fine and engine/shaft rotates freely. The fuel system is clogged with congealed fuel oil mix which I am cleaning out and the dismantling is progressing well. I am now approaching that critical decision point where I have to decide whether to just make it work with the minimum of fuss, or do the decent and time consuming thing of restoring the whole thing to look new!<br /><br />Time (and the wife's intervention) will tell!<br /><br />Thanks,<br /><br />Alistair
rolmops
Hello.<br />The B stands for "Belgium" as in made in belgium.
SCO
IMHO, Check your compression, geartrain, and see if smooth when it runs with the cheap fix, then decide if you want to put in new coils etc. If it is a good engine, I say make it reliable with the new electronics, carb kit, gaskets and seals and impeller. Sounds like a great motor project.
