Re: Breaking in Engine - How to?
jacob<br /><br />This is straight out of the Factory OMC Manual.<br /><br />Mix fuel at a 25:1 ratio for the first 10 Hours. <br /><br />FIRST HOUR: For the first 5-10 Minutes, operate the engine at fast idle. Make sure the water pump is working. For the remainder of the first hour, operate boat on plane, but not over 3000 RPM's<br /><br />SECOND HOUR: Bring boat on plane and reduce power to 4000RPM's. At intervals during the second hour, apply full throttle for 1 to 2 minutes, then reduce to 4000RPM's. Change speeds every 15 Minutes.<br /><br />3-10 HOURS<br /><br />Avoid continuous full throttle operation for the next 8 hours. Change engine speed every 15 Minutes. <br /><br />AFTER 10 HOURS:<br /><br />Switch to 50:1 oil mixture and Retorque head bolts after cylinder has cooled.<br /><br />Then head out and run it normally...
