Breaking in a Mercury 90
garry
I'm putting a new Mercury 90hp 2 stroke on my boat and wondered if anyone had any variations on break-in procedures from the owners manual that you think I should follow. I just read the post on oil (page 18) and not sure what to even use for oil now, always used TC-W3 certified oils before (any brand) but scored some cylinders and burned a hole in the #2 piston of a 125 Force motor, maybe the oil. Interested in longevity. How about after it is broke-in, I normally only run 3/4 throttle should I run WOT at the end of the day to blow out the carbon so to speak, if so for how long? Thanks Duffer
skier
Re: Breaking in a Mercury 90
As far as break in procedures, I'd follow the manual to the letter, using double the oil (QuickSilver) 24:1.<br /><br />As far as what oil to use, QuickSilver oil is made by the same company as your motor, so why not use it? Who knows better what the motor needs?<br /><br />No matter what I have been doing on the lake/river, I always run at WOT for at least 2-3 minutes just before the 5mph zone at the ramp. Weather you drive your boat onto the trailer or not. Always unplug the fuel line and run the motor dry. Really saves on having to rebuild carbs. The only carb that I had to rebuild was on a motor that I didn't own and the guy never ran it dry. I go as far as to run it dry when camping every time I get back to shore unbless I am going to head out real soon.<br /><br />I hope this helps.<br /><br />Craig
my new fishmaster
Break in use more oil in the system like putting it in the tank. Dont push it a new engine likes to be broke in slowly. Keep it under 4500rpm and boat at different speeds slow and faster.
RJS
If you have an EFI, the computer control automatically adjust the oil for you during the break-in. During the first hour, avoid extended periods of idle and full throttle. Try to keep the RPMs in between 3000 and 4000. Short bursts of full throttle are OK. The next three hours, vary the RPMs every 10 minutes. Its OK to open it up, but not for extended periods of time. Check the plugs and oil reservior after the break-in. I would also recommend changing the gear case oil.
rl29
Duffer: <br />This is what I found from Mastertech Marine. Its actually for breaking in a new powerhead. And I realize yours is a new motor but thought maybe you'd like to read it. www.maxrules.com<br />Break-in Proceedure<br /><br />Start your engine at home base using flush muffies to see that it actually does start and doesn't have any obvious problems i.e. - water leaks, etc... Once it is obvious the engine will start and run I suggest the engine be put in the lake and run for 20 minutes at high idle RPM (750 - 850) unloaded or out of gear. Check the plugs and carefully feel the engine to make sure it is not overheating. Restart the engine and then move it up to around 1500 RPM loaded in gear and vary the speed from idle until you have two hours on the engine. All the foregoing may be accomplished on the trailer. It is time consuming and tedious but it is the basis for long and happy engine life. If everything seems to be okay check the timing on #1 & #2 cylinders on a V-4 or V-6. Use the cylinder with the highest reading and set the timing 2-4 degrees less than the factory specs. If the spec is 24 degrees BTDC set the engine at 22 degrees. Leave the engine at this setting for the break-in period. If later you want more power the timing can be advanced to the factory spec but the engine will live longer if you leave the timing retarded. Don't guess. Use a timing light and set the timing UNDER LOAD, at FULL ADVANCE! Don't run it there other than to check the timing.<br /><br />At this point you can run the boat, cruise at 3000-3500 RPM, periodically giving it short runs up to full throttle. This should continue until there are ten hours on the engine, then your powerhead should be broken in. If you follow the outlined procedures you will get better service from your engine. Be sure that at maximum throttle the engine will turn up to 5500 RPM. If it doesn't the propeller should be changed until the engine runs at or slightly over the rated operating range with a light load. The wrong prop can cause the motor to lug, overheat or at the other extreme overrev and destroy all your good work. Be sure to check and retorque the cylinder head gaskets.<br /><br />Rebuilt Motor DO's and Don'ts<br /><br />You must determine the reason the original powerhead failed. If the problem is not identified and corrected it is almost certain the newly rebuilt powerhead will fail. If a restricted (lean) carburetion problem caused the original powerhead to fail, the new one will also fail unless the problem is corrected. Guaranteed!<br /><br />The most common causes of engine failure are detonation, pre-ignition, and overheating or any combination thereof. The result of these problems is that the temperature in the combustion chamber gets too high. As soon as the temperature in the chamber gets higher than normal the engine begins to run poorly and the damage to the engine begins. Detonation is usually caused by the air/fuel mixture being lean and the erosion of the piston starts at the edge or outer diameter of the piston. If the erosion starts in the center of the piston it is probably an ignition problem. An engine running hot due to deteriorated water pump or cooling system blockage compounds the problem.<br /><br />The other common failure mode I see is scuffing and/or cold seizure which occurs mostly in new or rebuilt engines. When the engine is started, the piston heats up and expands quicker than the cylinder walls which are liquid cooled. When the engine is broken in and running at the correct operating temperature it runs with around .002 clearance. Normal human hair is about .003 inches. Once the rings are seated and a glaze forms on the cylinder walls this problem is not likely to occur. This makes the break in period very critical. The proper break in of a new or rebuilt powerhead will help insure that you get good value from your investment.
Spidybot
From 30+ years of motoring and racing both vehicles and vessels I'd like to state, that oil is not always oil. 2-stroke oils indeed.<br /><br />Most oil sold by motor manufaturers are made by the big oil companies as not many really has the facilities to make oil themselves. Therefore a lot of oil can be found under more brands.<br /><br />But the fact that a manufacturer recommends an oil after researching and testing additives etc. should not be neglected. Anyway, the money going into oil is a very low portion of the boating cost so there's really now reason for taking chances.<br /><br />I've seen Merc parts come out of engine and they were blue from heat due to too high temps caused by insufficient lube.<br /><br />It is by using good oil all the time, you make the motor last longer.<br />My worst experience was branded Agip Racing 2-stroke oil that did not keep the specs. The oil was meant to withstand certain temperatures but didn't... it burned already when in the crank hence doing nothing in the cylinder. Totally spoiled pistons, cylinders and all bearings and bushes.<br /><br />Do also remember that marine oil and standard 2-stroke or snowmobile or whatever are not just the same. Working conditions differ (especially working temperature).<br /><br />4-strokes are less critical which also shows from manufaturers recommendings.<br /><br />Stick to the manufacturers advice. Get a bargain on it and rest assured.
FlyBoyMark
Ensign
Running double oil mix means the engine is running LEAN. You are displacing fuel with oil. The oil is not fuel. Fuel is also used to cool the engine. With higher combustion chamber temperatures with a leaner fuel mix, avoid continues maximum, WOT except for VERY short burst durations till the engine has passed its breakin period. :D
kart33
I have to disagree with Merc 140 He says to unplug the fuel line and save on carb rebuild, if you are oil injected you do not want to do this as the oil will fill the carb without the fuel and cause different problems..for what it's worth
skier
Your could be right kart33. I have never had an oil injected motor. I have the mix in your tank motor.<br /><br />Craig
