Breaking in 40 hp Merc oil injected
morgan833
How doI break in my 40 hp Merc with oil injection. I do not have any manuals
sharkcat
Re: Breaking in 40 hp Merc oil injected
Run it on 50.1 premix as well as the oil injection it will give it a double dose of oil.Use this for the first tank of fuel(2 tanks if you are using a small tank,just to be safe) & avoid continuous full throttle running.After the first tank has been used check that the oil level in the oil tank has dropped if it hasnt your oil injection isnt working.
morgan833
Thanks for the info great help.
Jack Shellac
Also important not to run it at the same speed for extended periods of time. Vary the speed so everything will seat right.
