140 mercruiser 1973. Old wiring harness on the engine was corroded in places so swapped it out for a new one and of course there are some extra wires for things that i dont have on my old engine. Shift interupter switch was never hooked up on my old engine come to find out. All I have is the wires going from a terminal block to the switch itself, no wires coming into it. new wiring harness has a green/white going from dist to what is supposed to go to my shift interupt as well as a purple wire. I plugged those wires into eachother to see if I would get spark to close the circuit but no spark. Does alternator have anything to do with spark? I have one purple wire hanging from my alternator there dosent seem to be a corresponding purple wire from my harness to go to it? i have 12 volts to coil and 12 volts to distributor? Dont make and sense. No ground wire to dist but thats what it seems like theres a bad ground.
Thanks for any help.
