Flyin1500
Thread starter- Joined
- May 31, 2007
- 83
Well,
I was a happy boat owner. Ran my 1984 Mercedes for about 4 hours before the #2 exhaust valve decided to bail and destroy the entire #2 cylinder (pics posted on an earlier thread). So I luck out (at least so I think) and find a rebuilt merc 120 on ebay. Here's the description:
This auction is for a Fresh 120 hp Mercruiser also know as a 153 Chevy 4 Cylinder engine
(0) Miles / Running Hours on it.
This Motor was Completely Professionaly Rebuilt
The entire motor has been hot tanked and maged for cracks
The block has been Bored and fine honed to ..030 over
New Speed Pro Pistons and Rings installed.
The rods were reconditioned as needed and new cam bearings were installed.
The Crankshaft has been turned and New Rod and Main bearings and seals and Brass Soft Plugs were installed.
This motor has a New cam and matching lifters installed
along with a New timing chain set and a New melling oil pump.
The Head has NEW Hardened Valve seats installed (for unleaded gas) with a 3 angle valve job and new valve seals were installed and it has been surfaced milled flat.
The engine has all New Felpro gaskets installed.
This motor is complete as you see it in the pictures, parts included in this auction are the crank adapter, oil pan and pick up tube, timing cover, Valve cover.
This motor is ready to bolt in and is in 100% new remanufactured condition.
So I get the motor for a great deal, and line up a guy to do the repower for me. (I don't have the time to turn my own wrenches). My mechanic says I need a new exhaust manifold cuz the other one is rusted through, so he gets said manifold and puts it on. Motor fires up and while he's adjusting the timing, hears water sounds coming out of the exhaust area. According to him, my new block was a newer style merc 120 and that my older one (1984 sn6789332) has an ever so slightly different manifold(not sure of the sn of that one). So he swaps the manifolds and gets it running good. The night it gets home, I figure I'd check the oil. Milkshake city. So I call my mechanic and he says that it's prolly from running it earlier with the wrong manifold and that might be where the water is coming from. He says change the oil and run it and we'll go from there. So I change it and the filter add more oil, and run it. Still milky. So I call the mechanic up and he says he knows it aint the manifold. I trust him, so I'm waiting to hear back from the guy I bought the block from. He told me when I bought it that there would be a 1 year warranty on it. Anyhow, mostly venting. How hard is it to do a leakdown test? And if there was a little bit of water left, how much would make the new oil milky? (Hoping that it's just residual water and not new, but Hey I'm an optimist) [\endrant]
