Bravo2 vs bravo1
paulie0735
Re: Bravo2 vs bravo1
Well it sounds like your set on the SB and going from SB to SB will be the easy route but as has been stated previously you’re already getting excellent results from your current 350 and bolting in another is not going to get you the 45 mph that you’re looking for. Peak horsepower figures of 330hp from a small block do not compare to similar ratings from BB's. They make power in very different ways and I really think you'll struggle to get the extra 8 mph that you’re looking for from any SBC that fits into your budget. Its likely that you'll spend the 5 g's and have a healthy engine that sounds great with that bigger cam and higher compression but you will likely be disappointed with the 3 - 5 mph that you gain, not to mention the extra fuel she'll be demanding to get there. As for the 4 blade v's 3 I would take your own advice and wait till your re-power is finished and than go shopping for the right prop. Lots of help in that area here when you’re ready for it! <br /><br />On another note, what type of cooling system are you running, closed or open? The Vortec option you have mentioned will likely require a closed cooling system so you may have to budget that in also.
TilliamWe
Banned
hudman, have you decided to replace that Bravo 2? My dad just broke his port side Bravo 2 this weekend, and he needs an upper! He'd come to TN from FL if the price was right! :D
hudman
Nope, going to keep it... got a new 350 vortec being converted to a 377 cu in motor. looking for around 375 ph at 4400 rpm and still relaible<br />check e bay, everyone is having a jan sale<br />hud
paulrfrancisco
I read all the commentary and a 330hp Small Block will likely consume the abount same Fuel, but have way less torque than a 330hp Big block. This in turn means the BB will work a lot less hard to push you around.
rodbolt
also be aware that with that 400 crank you MUST run a 400 flywheel and balancer. make sure the balancer will work with your current drive accesories. for not much more you can get a 7.4 from marine power or an 8.1 or 8.2 that will drop in and bolt up and still have a few years of warrenty anywhere in the states. myself I dont see much speed gain with a 377 or a 383 stroker. you can also buy a 6.2 (sbc) that will drop in.<br /> but if ya really want to play wait a year or two and see if merc releases the chysler V-10 for marine use. that should be fun :) . they are prototyping it and so far its working quite well from what I hear.
I/O WALDO
I repowered a 1989 Chaparral 278XLC 7.4 ltr.330hp Bravo1 17" 3blade stainless with a 502efi magnum 410hp,same drive,19"stainless and gained 5mph!It takes BIG hp.changes for REAL results!!(7.4 turned 4800rpn,502-5100rpm)
I/O WALDO
B2 issa tugboat drive,whatzit on,lemmy guess...a BAYLINER?
hudman
So you like bayliners waldo?
hudman
I/O WALDO
NAW, butt sea a lot of b2s on that 27ft hardtop express they make.(Bayliner name means,"Lines the bottom o the bay"
hudman
this is a rinker , 266 fiesta vee, hate to dissappoint you.
I/O WALDO
They (Fiesta Vee) usually have(depending on year)a very efficient hull design.Still,the b2 is not a speed butt a cruise drive.Nice boat though!Sorry bout the Bayliner insult!
