Bravo1 with dual water pickup- is lower pickup needed?
J.J
Hi, we have a 350mpi eng running a bravo1 leg with dual water pickups. I have had the lower pickups on the front of the gear drive blocked up with sand a couple of times when launching and hitting sand bars and also this system is difficult to flush after use. Does anyone know if it would still get sufficient water to the pump from the side intakes if the front intake holes were filled in and blocked off ? Thanks. J.J
