Doggonitt
Thread starter- Joined
- Jun 14, 2009
- 19
While getting ready to prep our bravo 2 sterndrives for painting, I took a close look all around to check out the units. I noticed one of the wear pads missing from our starboard sterndrive on the outside of the drive. I don't know how long it has been missing, and probably wouldn't have even noticed it except I looked at both drives together. I had to search the internet to even find what they were. The bravo Manual, #11 does not show that part at all. (My sterndrives are 1998). Exactly what do they do? I cannot find any info on them. Also, on the starboard drive the ujoint assembly has a very fine layer of rust (both were covered with black trash bags for the winter in Mass.) Only this one has the rust. I was wondering if I could use a rust remover to clean it up before greasing it to be joined with the bell housing. And one more question. While looking over the drives and transom, I noticed only the plate anodes were bad. All anodes were replaced last season. The trim cylinder, trim tabs, and trim fins were all fine, almost no wear at all. I don't know which to be more concerned about. I think I might have used mixed zinc and aluminum anodes because I had spares, but don't know which ones were which. I checked to make sure of the 1 1/2 inch no paint zone around the housing, it was ok. The mercathode is ok also.
Just wondering why. It looks like my starboard drive was in much poorer shape all around. Again, don't know why. That drive is also missing the trim-in limit spacer. It's a mystery
