Bravo Three Sticky gear selector
bncponder
I have a 1996 Bravo Three sterndrive that has sticky gear selection. And when I say sticky, I mean can't get it into forward and have a hard time in reverse. I replaced the lower shift cable first (I've already ruled out the upper cable). When I had the sterndrive on the ground, I was able to move linkage between gears (harder to get in reverse than forward), the same as it was while it was installed. I replaced the cable and got it all back together and now its hard to select either gear. This post may be premature as I spent most of the evening doing the cable replacement and I'm a little frustrated, but I haven't put oil back into the drive yet.......could this be my problem? Or is there something else to check?
I did pull off the cover at the back of the sterndrive (the one with three bolts) to check out the linkage....looked OK.
Please....any help would be greatly appretiated.
Thanks
PuddleJumper
Re: Bravo Three Sticky gear selector
I've heard that Bravo drives should only be shifted while engine running. Could be you won't have the problem when you have the engine running.
