Bravo 3 not going into gear
Bravo402
Need some help guys. Took the boat out yesterday was running perfect then all sudden boat stopped put it in netural and shut motor down checked everything looked good. Fired up the motor went put it in gear and it was very hard to do and motor would rev up wasn't in gear then tried reverse same thing. Thought maybe the shifter cable broke. Took the outdrive off far enough to check the cable all is good there goes back and forth as it should. So I then took the outdrive completely off the boat. When I turn the shaft in any direction the props do not turn. I'm lost on what to do next any help would be appreciated.
alldodge
Start by checking the gear lube color. If good, and you cannot move the shift fork on the drive and engage the drive shaft with the prop, then remove the top cap off the drive. My guess is there may be some broken gears.
When was the drive lube last changed?
Bravo402
I bought the boat last year and it had the 100 hour service done to it and was told it was changed . It has 132 hours total on the boat
Bravo402
Im afraid I have some broken gears in it. In thinking my problem is in the upper part of the outdrive
Bravo402
When I unscrewed the top vent screw had a lot of air come out. And found some metal on the screw. Not looking good for the home team
alldodge
Sure sorry to hear, but it sounded like melted gears.
Not that it will help but was your drive lube bottle empty?
Bravo402
No it was at the full line. What the best course of action replace both upper and lower or the upper? Anyone know best place to get one at?
alldodge
The bottles are good sight glasses but they to require maintenance. Every few years when lube is changed the bottle needs to be emptied, clean out with diesel or mineral sprits, then refilled. The issue is the lube container gets clogged up and does not pass back to the drive.
There are several places which sell them, but I would recommend replacing the entire drive unless you are willing to take it completely apart, cleaned and reassembled. Don't go with an upper only without rebuilding the lower.
Look at Offshore Only.com they have a swap and a classified section, Craigs list but beware. Depending on what ratio you need I might have an idea.
