Re: Bravo 3 Gimbal Housing Seal
Why are you replacing the shaft? I can't imagine it being worn out?
Well, that's a very good question! The gimbal ring is worn at the upper shaft, seems someone didn't keep the proper torque on the u-bolt. I'm not sure what should be replaced, other than the gimbal ring.
There does not appear to be any wear on the upper shaft (I realize its steel and the gimbal ring is aluminum), but I have read in other places that the shaft and u-bolt should be replaced when replacing the gimbal ring (I never over torqued the u-bolt, but can't speak for the original owner).
The upper and lower shafts came out easily. There does not appear to be any wear on any of the upper or lower bushings or seal. The upper shaft only has some slight discoloration but no wear where it contacted the worn area of the gimbal ring.
So I quess my question is, assuming there are no signs of wear on any of the upper and lower shaft components, what should be replaced?
