Thundercraft350Z
- Jan 19, 2011
- 2
Hello everyone,
I have a fairly simple question: My bravo 2 merc leg oil reservoir was almost full at the beginning of the season 2 months ago. It is now nearly empty. Is this normal? should I be worried that my leg has an oil leak? Should I just add oil or could this be that that the actual leg oil has mixed with water and running the boat would be dangerous. I guess this could also be an in-cabin leak since I did notice a little bit of oil in the small amount of water under the engine.
I guess I just want to make sure I don't add oil only to find out that there is a leak on the leg and oil is mixing with water.
Thanks!
Thanks!
