bravo 1 u joint
995jim
Hello, my bravo1 has developed a new noise. I just had my transom and stringers at engine restructured. After a few trips out on the water I noticed when the i turn the wheel all the way to starboard it sounds like the u joint is binding or fluttering noise. with each revolution at idle. I could feel the vibration all the way up through to the steering wheel. the u joint was just greased and didnt seem to have signs of bearing failure. So im not sure if it would be the engine alignment when reinstalled, a steering adjustment, or the ujoint itself. There isnt any vibration or noticable noise otherwise. any ideas? thanks jim
Scott06
I would recheck the alignment several times and rotate the coupler 90 deg 4 times to check alignment through the arc of coupler rotation. U joints can be tough to see wear with out taking the caps off. The ujoints on my Alpha gen 2 felt fine but when I resealed my drive I replaced them 1-2 crosses on both joints had ribbed wear on them. these were permalube joints that never got wet... basically throw them out after 300 hr.
if they are the same ones with external circlips a moog 344 or equivalent will work
tpenfield
I would check the alignment. U-joints don't like to turn all the way, particularly with power applied. A u-joint can feel OK, but be worn enough to cause the noise/vibration that you are experiencing.
