I am rebuilding my boat's transom and have removed one Bravo 1 transom assembly, which had eight 7/16" studs. These studs have course threads screwing into the transom assembly and fine threads on the opposite ends for locknuts.Four of the eight 7/16" studs went all the way through the aluminum transom assembly and are exposed to salt water. The remaining four bottomed-out inside the aluminum transom assembly. My MC manual provides torque values of all eight studs but does not say what sealant is to use on the 4 bolts that go through the assembly and exposed to salt water. Any suggestions? It seems to me that aviation sealant would be find.
