Bravo 1 Transom studs' sealant?
tank1949
I am rebuilding my boat's transom and have removed one Bravo 1 transom assembly, which had eight 7/16" studs. These studs have course threads screwing into the transom assembly and fine threads on the opposite ends for locknuts.Four of the eight 7/16" studs went all the way through the aluminum transom assembly and are exposed to salt water. The remaining four bottomed-out inside the aluminum transom assembly. My MC manual provides torque values of all eight studs but does not say what sealant is to use on the 4 bolts that go through the assembly and exposed to salt water. Any suggestions? It seems to me that aviation sealant would be find.
Oshkosh1
Ensign
Why would sealant meant for aircraft flying in a dry environment be "fine" for a marine application?
Use marine grade 3M 5200...
tank1949
It stays tacky. 5200 is good too! Manual may call for locktite but I cannot find any mention of 5200 or other stuff.
Ayuh,..... I put Perfect Seal on the threads, before screwin' things together,.....
Stops the bolts from corroding to the housin's,....
before aviation sealant was called aviation sealant.....it was simply called permatex #3.
Permatex #3 is what i have been using for decades. came out of early OMC, Volvo and Mercruiser manuals. (granted, they each call it something else, as well as state "can substitute permatex #3"
5200 is the wrong product in this application
tank1949
Others have stated that perfect seal is the same stuff as P #3. THX...but I am not real sure that these 4 studs require locktite or similar. If these bolts come lose, water will come in via bolt hole. I cannot find anything in my MC manual on exactly what to use. Perhaps MC doesn't consider these bolts to be significant? THX!
AShipShow
On my rebuild I used loctite on the threads and then a couple thick coats of paint over the exposed studs... but then again, I'm in fresh water...
Oshkosh1
Ensign
IF you're sealing them THROUGH the transom then 5200 IS what you want to use.
If you're just sealing the gaskets or threads then the red #3 is fine. It's little more than dyed rubber cement. I use it to hold gaskets on engines I build.
For everything requiring an RTV I use my industrial gun full of "The Right Stuff"...I use it like Franks Red Hot...
I guess I'm not clear on exactly what it is you're sealing up...
tank1949
The 8 studs have course threads that screw directly into the aluminum Bravo 1 transom assembly. I had to remove most of them from inside my boat because they had rusted to the transom's wood and glass. I could not get assembly off without removing studs from the inside of the boat. The rust had swollen between the wood/glass. I will have to replace the studs that are badly rusted. Therefore, when I install new studs into the aluminum Bravo 1 transom assembly and torque them, I'd like to know what is the acceptable MC sealant: perfect seal, aviation #3, 5200, Lockktite, etc. I realize that 5200 is the best sealant for the exposed studs part passing THRU the rebuilt wood or coosa board transom. This boat will be exposed to salt water.
