skyman2112
- Aug 7, 2015
- 78
Well my excitement over the water pressure issue was short lived, apparently that was not the problem it just improved it marginally.Great news, thanks for the update.
I went ahead and added another water inlet to the bottom of the boat and just T'd it into the supply line. Helped a little bit but still takes a long time, like 20 seconds, to build up 1psi.
Finally put a hose clamp on the outlet of the PS cooler and tightened it down a little to give it a some back pressure, now it only takes 10 seconds to get 1psi and still runs cool. Also replaced the cheap china thermostat with OEM cause it was cycling up and down to much. Helped some, its about 7 seconds now to get 1psi so i think the alarm will stay off now
