Bravo 1 gimbal housing
roy c
The studs that are on the gimbal housing can they be replaced ? do not want to put gimbal
back with same studs thanks roy
southkogs
Assuming it's a Bravo 1, you'll do better over here in the Mercruiser forum.
Ayuh,.... It's an aluminum housin', with steel studs, so Ya, sure,....
It might take some heat to loosen the old ones though,....
