bow mounting fish finder
feeshphace
hello all, i have a brand new tracker pro guide v-16sc i'm trying to add a bow mounted fish finder to. i found the accesory wiring in the bow but the terminals read no voltage when i check them with a multitester. has anyone run across this situation and if so is it just a matter of adding a fuse to the fuse box to make the circuit live? i tried to trace the wires but it proved impossible due to the fact they are all wrapped in shielding. any help with this problem would be greatly appreciated. thank you
jjrobiso
Re: bow mounting fish finder
Make sure switch (if any) is on. Fuse is in and working, and then do your best to trace wire, color, size, etc... check your boat manual or even call Bass Pro and talk to them. I'm sure they can help you out.
Silvertip
Honorary Supreme Mariner
Check the wire color up front. Then look at the switches to see if one of the AUX switches has that color wire on the LOAD side. Follow the wire on the the LINE side of the switch back to the fuse fuse panel and see if there is a fuse installed in that position.
gt
Different boat, but I have a master switch that needs to be on for the bow finder to have power? Have you tried that?
