Bow mount 55lb thrust trolling motor on a 10ft aluminium boat OOPS!
burtonwf
Yes I know a 55lb thrust trolling motor on a 10ft aluminium boat is over kill! I did it because Min Kota only had some things I wanted on the trolling motor in it's 55lb thrust product line. I also thaught the 55lb thrust would give me more power and control with wind and current issues and that was my OOPS. Here is what happened; With battery, charger, motor and wood to build the conpartment I have about 50lb in the bow of my boat and no weihgt on the transom. I seated myself in the center of the boat and left the dock. I headed into about a 10mph to 15mph wind at low speed. As I added more speed the boat started to fish tail and became uncontorlable as I reached top speed, heading into the wind. I also had the same problem with the wind at my back. My new trolling motor also comes with an auto pilot and the same thing happened when I tried to use it. WHAT HAPPENED? What did I do wrong and how do I correct it?
Don S
Re: Bow mount 55lb thrust trolling motor on a 10ft aluminium boat OOPS!
You put the motor on the back of the boat, not the front.
burtonwf
Don, it's a bow mount trolling motor. All of the information I have read on this forem says that a bow mount trolling motor is the way to go to beat wind and current issues.
WIMUSKY
On a 10' footer I would have gone with a transom mount. 16' + I would use a bow mount, or maybe even some of the wider 14'ers. I had an older 14' and used a transom mount.....
Maclin
You could try relocating battery and charger in the back using heavy wiring between there and the motor up front.
gm280
WOW 55 pound of thrust on a 10' aluminum boat...does it actually plane the boat...? :facepalm:
Yes it does seem you have a huge balance issue... Move things around to see if that helps.
burtonwf
What if I simply sit in the back seat of the boat or add another person in the boat, sitting in the back seat? Would that balance the boat out and make it more controlable? Well gm280 it might if I could stop the fish tail but that was not my objective for rigging it the way I did.
Silvertip
Honorary Supreme Mariner
Just like an airplane, boats can have CG (center of gravity) issues. Sit in the back and see what happens. Doing nothing different doesn't solve the problem or at least provide other data to chew on. Does the hull have a hook in it.
ondarvr
Bow heavy boats don't track well, you found that part out, just move stuff, possibly you, to the back until the balance is right. It will work fine once you get the balance corrected.
ngt
Master Chief Petty Officer
I hope I don't have that issue. I'm putting one on my 12ft alum, but I have a 9.8 Tohatsu in the back to balance it out. Still not sure there I'm going to set the battery up.
burtonwf
Thank you "ondarvr" I will try to find where my best weight and positioning balance is for my situation. "ngt" I hope you don't get the same result I did because it is a real bummer. I placed the battery and charger in the space between the front bench seat and the bow because it was a big enough area and it was out of the way. It also gave me a good platform on which to mount my motor. I also have a 7.5hp outboard that I can put on the transom but I was concerned about a weight problem. I could use all of the input possible regarding all of these issues form you guys out there.
burtonwf
"Silvertip" Not that I know of, the keel is in line as fare as I know. So if I have 50lb in the bow I need at least 50lb in the back of the boat as well? I am looking at almost 700lb with 100lb to balance the boat, two people at about 250lb each and fishing gear in a 10ft boat. Am I looking at overloading my boat or do I have a little room to play with? I need some input from all of you guys out there.
NYBo
That sounds like too much weight. Does it still have the weight capacity plate?
pikefisherman
How much weight is going to be in this boat? Be careful!
ondarvr
I need to back up a little and ask about the boat. There are 10' boats that can handle this easily, and there are 10' boats that are almost overloaded with nothing in them. What do you have?
Silvertip
Center of gravity doesn't mean "middle of the boat" and because you put 50# up front doesn't mean you must put 50# in back. You need to determine WHY the boat is doing what it is that you don't like. The only way to determine that is experiment. Leave things as they are -- sit in back -- run the boat! Is it now better, worse, or the same as before. If it is better than before you are bow heavy. So you then move stuff to the rear. If it is worse, I have no idea what to tell you. If it is the same, move more stuff to the rear. For all you know, the boat may already be overloaded and way too bow heavy. Move stuff around.
CharlieB
Front drive with NO RUDDER in the rear leaves the rear of the boat too free to swing.
Simply adding weight to the rear may reduce your problem, having a rudder in the water would make a big improvement.
You could leave most of the weight out but fab a rudder to make the rear of the boat track straight.
burtonwf
"ondarvr" My boat is 10ft long aluminum "V" hull, 50" at the beam and 19" deep (gunwale to the keel) What should a safe weight be for a boat this size? The data plate has been painted over and has no information stamped into the metal.
burtonwf
"CharlieB" A rudder sounds interesting and I may try it if I can't get my balance problem solved. One question; would an outboard motor be enough of a rudder or would it take more rudder surface area?
ondarvr
That isn't enough info to say one way or the other. There must be a make and model # on the title, you can look up the spec's with that info.
