Bow eye
doomanmxz99
Hey guys I have an 1989 Manitou pontoon that does not have a bow eye but I would like to put one on. has anyone done this and if you did how ???? If you have some pics that would be great Thanks
5150abf
Re: Bow eye
Should be pretty easy to have one welded to the tube, the problem would be getting one but that is such a common part really anyhting you get shoudl be fine so go to your nearest dealer that sells pontoons and have them order you a couple, they proabably have a good welder they use too.
EGlideRider
Re: Bow eye
Depending on your forward deck, you may be able to install a couple of stainless U bolts through the deck at a crossmember location.
doomanmxz99
Re: Bow eye
I have them on the toons already but want to put one on the center so I can hook my winch to it.
EGlideRider
Re: Bow eye
You will want that eye under the deck. A common method is to place a peice of aluminum between the front two cross members and put the eye on this peice of metal. This will distribute the forces between the two front crossmembers.
doomanmxz99
Re: Bow eye
Does anybody have pics???? How thick should I get the aluminum??? Thanks
rickdb1boat
Re: Bow eye
The aluminum should be about 1/4" thick and bolted to 2 crossmembers like EGliderider suggested. Here's pic of how mine is mounted..
doomanmxz99
Re: Bow eye
Thanks for the replies but rickdb1boat couldnt open the link you put up.
vergil
Re: Bow eye
my ol toon had a hole in the front molding on the bow anyway so i just put a big stainless steel I bolt through it, though my trailer is harsh on the ol eyes it pulls really good amd the bolt hold pretty good plus i have a place to tie it off on when we get to a bank or where we camp and i dont have to mess with something under the boat when we tie off
doomanmxz99
Re: Bow eye
Thanks for all the replies and pics now if it would stop snowing I could get to work.
Silver Eagle
Master Chief Petty Officer
Re: Bow eye
I put a big eye bolt in the top front of the center. And I backed it up with a piece of 2x6 so it wouldn't brake loose. The wood is screwed and glued to the plywood decking underneigth
