lonemust
Thread starter- Joined
- Apr 2, 2009
- 205
Re: Bow bounce? not rise.
Yes the ones I have on there now are an "L" shape. They were on the boat when I bought it. They do have an adjustable bolt in the middle. I just don't know how to set them.
The hull won't break in half. The tabs you have look like just L shaped plates which essentially just extend off the back parallel to the hull running surface.
Other recommendations to put weight forward will help to a certain extent.
I think Smart Tabs would be your best bet though, replacing the "tabs" you have now. The smart tabs will act almost like a shock absorber, which is pretty much what they are, a shock absorber attached to a trim tab. When the bow starts to rise, the tabs will bite the water more, helping to keep the front down. When you are on a good plane, the pressure from the water will help keep the tabs compressed so they won't affect top speed much.
