Boston Whaler Full Restore From Bare Fiberglass (gelcoat or paint or what)
Status
Not open for further replies.
sshawn
Re: Boston Whaler Full Restore From Bare Fiberglass (gelcoat or paint or what)
What are thoughts on moisture meters? Can I get a 10 dollar gig from home depot used for gardening and avoid drilling 1.5 inch holes to tell if its wet in there? I'd love to hear 1/4 inch holes and a home depot meter will do the trick.
Shawn
ondarvr
Does gelcoat require primer? After the most faded white, it slowly reveals a grey (but it might be a mix of white and the glass). After cleaning up the gray I hit clearish glass.
Shawn
Sometimes builders use a black or very dark grey backup gel coat behind the white, they do this because it's easier to see air the bubbles and roll them out when there is a dark background. So it is possible for there to be white gel coat over the the grey, then the clearisih layer is the first layer of glass.
hello everybody im new to the forum but not to boating or repair so much... i have task very similar to yours sshawn.
i am completely redoing my 1972 boston whaler 21 outrage.. as well as re gel-coating the whole boat. from keel to rub-rail. i have the boat completely stripped and the boat flipped over ready to go. i read how some you were saying it is very hard to remove gel coat... not anymore i recently came upon a product called the marine shaver pro this machine is a beast on gel coat and can strip at 1 sq ft every 20 seconds i will post the pictures of my boat and the restoration as i go.. any advice would be appreciated. thanks
GA_Boater
bostonwhalerproject
This thread is over 5 years old and it's been that long since sshawn was here. Way past our 90 days of inactivity rule.
When you do start showing your resto, start a thread of your own.
Status
