Divecaptchris
- Jan 30, 2009
- 143
83 Carver Mariner, Twin 350's, borg and warner velvet drive trannys and Walther V-Drives. I just put a new starboard motor in (Was blown when i bought the boat so i had no clue of the condition of the drive train) Motor runs great, works fine in reverse, however when u go to shift into forward after about an inch of travel i feel try to kick into gear but as u push the lever forward it is no longer engaged, if u pull the lever back to about 1 inch from neutral it will try to go into gear, and if I play with the lever in that area i can get it to stay in gear for bit but if i raise the throttle is seams to go out. so Then i viewed the shaft off the transmission once i got it to stay in gear, and when i raise the throttle the shat is turning just doesn't seam to turn faster!(ie slipping?) so anyway is there anyone out there familiar with these tranys? is there anything i can try before i have to remove the motor again and try to get into the tranny? I do know that i have the correct rotation engine, and it is the same rotation as the old one, cant think of any more info i can give, Hope someone has some insight!@
