lakelover
Thread starter- Joined
- Mar 26, 2003
- 4,390
I'm about to make a new fireplace for the back yard, just a simple one, nothing fancy.
The plan is to construct it using landscaping stone blocks, and I want to line the inside of the walls with firebrick. I'm planning to stick the stones together with Liquid Nails Fuze-It. I figure that will be OK if I apply it mostly toward the outer edges away from the highest heat from the fire. I don't know why I can't put the link in for this, but the stones are "Olde Manor Allegheny Retaining Wall Block (Common: 4-in x 12-in; Actual: 3.5-in x 11.5-in)" from Lowes.
Any thoughts on how to bond the firebrick to the stones for outdoors? Every product I've seen says "not for exterior use", so it looks like regular stove cement won't fit the bill.
